Sending email from FME server
  • Aug 25, 2020 8:45 PM UTC
  • 100 views
boubcher
Forum|alt.badge.img+11
@david_r
I am using fme server 2018, have a simple workspace to send an email
but I am getting this error
I had tried to change the description to all option there ( SSL,TLS , NONE )
but still getting this error
Report_Emailer_2: <class 'smtplib.SMTPNotSupportedError'>: SMTP AUTH extension not supported by server.The below feature caused the translation to be terminated
siennaatsafe
Forum|alt.badge.img+12
Hi @boubcher​ ,
Can you show how you are setting up your Emailer Transformer? Does this workspace work in Desktop? What Email Service are you using?
If you are using Gmail you may have to enable less secure apps in Gmail as @david_r​ describes here: https://community.safe.com/s/question/0D54Q000080hM7vSAE/email-from-fme-desktop-2015
boubcher
  • Aug 27, 2020 1:20 PM UTC
Hi @boubcher​ ,
@siennaatsafe​  Thanks for your replay , I am not using the gmail
can we connect via email to send you all the required info
Thanks
