s3connector disappears in one 2020.1.3 installation
  • Apr 23, 2021 1:47 AM UTC
  • 100 views
aguan
Forum|alt.badge.img+11
I had a workbench created with desktop 2019.2.1. It had a s3connector in it and worked fine for over 6 months now. I recently installed 2020.1.3 on the same machine, the workbench worked fine in 2020.1.3 and was saved in 2020.1.3. Today, I installed 2020.1.3 on two other machines which had not had any FME installed before. The workbench works fine on one machine, but on the other machine, at opening, it gives an error related to the s3connector. See attached screen capture. It then opens the workspace, but the s3connector is gone. Is there a way to fix this? I really want this workbench to work on this machine.
Best answer by nielsgerrits
@nielsgerrits, it does not appear on the canvas on this machine. Maybe I can copy it from the other machine if I can find where it is located? It also misses this very useful custom GeographicAreaCalculator.
@aguan​ Workbench might have limited acces to the internet? You can also download the package from the FME Hub and install manually.
nielsgerrits
Forum|alt.badge.img+67
It looks like the S3Connector package is missing on the not working machine. Add the S3Connector to the canvas to install it.
2021-04-23_06h39_27
aguan
  • Apr 23, 2021 1:45 PM UTC
2021-04-23_06h39_27
nielsgerrits
  • Apr 23, 2021 5:34 PM UTC
aguan
  • Apr 26, 2021 1:27 PM UTC
Thanks, just downloaded the package from Hub and installed.
