Run once for each feature or once on the collection?
  • Mar 23, 2022 11:06 PM UTC
  • 6 replies
  • 61 views
mattwilkie
Forum|alt.badge.img+11
I'm working on a script someone else wrote. Is this stored SQL procedure going to be executed for once for each incoming feature, or once on the collection of features?
100,000 features feeding into an SQl Executor
Best answer by redgeographics
The SQLExecutor will trigger once per feature, so in this case 100000 times.
If you only want to run it once you can use e.g. a Sampler to split off one feature to trigger it, or aggregate the data first (and then deaggregate later), although with 100000 features that's probably going to be a performance hit.
Forum|alt.badge.img+63
mattwilkie
  • Mar 24, 2022 3:58 PM UTC
Thanks! I'm glad I took the time to ask. :-)
You're welcome! The HTTPCaller works in the same one (one request per feature) so I once ended up doing a DOS attack by mistake 😅
mark2atsafe
Forum|alt.badge.img+59
I haven't done that, but I have managed to send multiple emails by mistake. Thankfully I had a lot fewer features than 100,000
mattwilkie
  • Mar 28, 2022 7:09 PM UTC
This case was almost the worst possible combination. It turns out the stored procedure was copying all records from one table to another, so 100,000 FME features * copy 540,000 rows. 😨
Oh wow! Yeah, that would have been bad!
