Remove lines where the lenght is longer outside than inside polygon
  • Sep 22, 2020 1:15 PM UTC
  • 87 views
souryana
Forum|alt.badge.img+12
I have a layer with polylines that intersect with polygons where I use the method intersection (Spatial filter). I want to remove those lines where bigger parts of the line is outside than inside a polygon. How should I proceed?
BR
  • Sep 22, 2020 2:05 PM UTC
Does a polyline always intersect just a single polygon like the left figure? Or can a polyline intersect two or more polygons like the right figure?
intersections
Forum|alt.badge.img+54
  • Sep 22, 2020 2:07 PM UTC
I'd follow this process
  • Calculate the length of the lines
  • Store the geometry as an attribute
  • Clip the lines with the polygons
  • Calculate the length of the clipped lines inside the polygon
  • Test if that length is greater than 50%
  • Recreate the original geometry from the attribute stored in step 2
Capture
