Relate Records and update a field
  • Dec 1, 2022 6:15 PM UTC
  • 67 views
vxn43
Forum|alt.badge.img+20
I have two Geodatabase Feature Classes, FC1 and FC2.
I want to relate the GIS_ADDR field in FC1 to the ADDR_BASE field in FC2.
Once the relate is established, for the matching (selected) records in GIS_ADDR in FC1, I will then update the ADDR_SRCE field which is currently empty with the value "ADS"; for the records that do not match I will add the value "Res".
I know how to do this in ArcGIS Pro. What is the best approach to do this in FME?
Best answer by dustin
I would use a FeatureMerger. FC1 would go into the Requestor port, FC2 would go into the Supplier port. You will need to set the GIS_ADDR and ADDR_BASE fields in the Join On parameters of the FeatureMerger. Then from the Merged and UnmergedRequestor ports, feed those into 2 separate AttributeCreators. In each of those you can set the ADDR_SRCE field to your values.
dustin
Forum|alt.badge.img+36
  • Dec 1, 2022 6:43 PM UTC
vxn43
  • Dec 1, 2022 6:56 PM UTC
@dustin​ thank you. I also tried it using AttributeManager instead of AttributeCreator. That also worked. Your suggestion seems more logical.
