Reading/Writing ArcGIS Enterprise Branch Version Service
  • Dec 11, 2023 5:52 PM UTC
  • 0 replies
  • 410 views
sashal
Forum|alt.badge.img+13
From my testing, when reading data that is branch versioned from an ArcGIS Enterprise Feature Layer, it seems there is a limitation on the FME Reader side as to how many layers can be in the ArcGIS Feature Service. For example, if I publish a service which has one layer, the FME reader can read successfully. But, if I publish as service which has multiple layers, the FME Reader reads the schema, but fails to read features.
Are there any known requirements or limitations in FME readers and writers when connecting to branch versioned ArcGIS Enterprise Feature Layers? Has anyone else seen this behavior? If so, what workarounds do you use? I would like to avoid having mulitple published services for a logical grouping of data.
Thanks in advance!
