Read geometry from Sqlite
  • Oct 30, 2023 1:32 PM UTC
  • 207 views
marketa
Hello,
is it possible to read geometry from Sqlite in FME 2023? In FME 2022 I was using SQLite Spatial (GDAL) (deprecated), but I'm missing this format in the new version.
Thank you.
  • Oct 30, 2023 1:46 PM UTC
marketa
  • Oct 30, 2023 2:11 PM UTC
I tried this format and it did not work. I'm still having the same problem that the geometry is not read:
imagewhen using SQLite creator with the same query, the geometry is read properly in FME 2022:
