RasterDEMGenerator Issue
  • Jun 22, 2022 12:04 PM UTC
  • 94 views
od10
Forum|alt.badge.img+4
Hello,
Please can someone help me with this very strange issue i have encountered with the RasterDEMGenerator transformer.
I have uploaded some sample data and the sample workbench. The input features have 40 vertices to pass through to the RasterDEMGenerator but it fails each time, whereas when i add in another transformer - PointCloudCombiner before the RasterDEMGenerator it works fine.
I need to get to the bottom of this issue as i cannot use the PointCloudCombiner transformer.
Many thanks
@Mark Stoakes​ @Takashi Iijima​ @danatsafe​
nielsgerrits
Forum|alt.badge.img+67
I have not checked your data yet, but what is the grid distance of the vertices and what is the cell size in the RasterDEMGenerator?
od10
  • Jun 22, 2022 12:59 PM UTC
The vertices are spaced every 10m or so, and the cell size is set to 2m so this shouldnt be the issue
nielsgerrits
The coordinates in your dataset have 9 decimals, which is extremely small in meters. Rounding the coordinates to mm (3 decimals) got it working for me.
As an alternative, changing the Surface Tolerance from 0 to something really small worked as well.
