Range testing
  • Aug 20, 2020 9:57 PM UTC
  • 195 views
boubcher
Forum|alt.badge.img+11
Hello there
I have data with attribute name : provider_id ,
the user will upload this data via a published workspace, but I need to make sure the user upload only data with a range of provider_id
in the work space I am reading the fme_server user,  then filter authorized provider_id value ,
now how can make sure the provider_id values in the data is in the range from that excel sheet
Range
danilo_fme
Forum|alt.badge.img+58
  • Aug 21, 2020 1:03 AM UTC
Hi @boubcher​
If you use the transformer FeatureMerger ( Informations from FMEServer * Excel File ) then use the transformer Tester ?
Thanks in Advance,
Danilo
