Questions relates to shortest pathfinder
  • Jul 13, 2023 5:36 PM UTC
  • 106 views
gogopotter90
Forum|alt.badge.img+14
Hello ,
i have many start node and several end nodes and network that I am using as input for shortest path finder .
My problem :
i have found the paths that I want from start to end .
  1. how could I remove the overlap parts of path ,because i have found that some paths uses the same network to reach different end nodes .
  2. there are intermediate points locates on the network ,so I would like to know the id of each point (from direction start node to end node ) .
as example , the next point after start node has id 389 then next 490 then next 999 then ……
i would like to know ( 389 connects to next 490
and 490 connects to 999 till reach the end of the path )
fme 2021
thanks for help .
geomancer
Forum|alt.badge.img+71
  • Jul 14, 2023 12:11 PM UTC
Use a Chopper (2 vertices) and a Linecombiner.
Next use a PointOnLineOverlayer to add the ID's of the start and end vertex to the lines (generate a list containing the vertex ID's on output 'Line', and turn the list values into attributes).
gogopotter90
  • Jul 14, 2023 7:19 PM UTC
Thanks for ur idea .
Could u please upload the Fme workspace to understand it better .
i am still confused about sth , the point that I will use as input for point on line ,
it should be the point that I want to find on line but how to reorder theses points .
because I think ,it brings me the output but not reordered it .
i have got the path from start node to end node (from beginning of line to end of line )
important for me to find the intermediate points and reorder them at the same direction .
I have used start node and end node as input from to line but I did not use any intermediate points but I got the paths that I want .
But it is still not clear for me ,how will reorder the intermediate point .
if says
A start node
intermediate points :
g to k
k to f
f to c
f to c
all of them has same id when it locates at same path
till reach to end of the path
end node : c to h
if u have sammele workspace ,could u upload it .
Thanks for help
