Python Exception <ModuleNotFoundError>: No module named 'fmepy_autodesk_bim360docs'
  • Nov 1, 2023 11:28 AM UTC
  • 56 views
mspencer
Hi, I'm receiving a "Python Exception <ModuleNotFoundError>: No module named 'fmepy_autodesk_bim360docs'" error when running a workspace. I've checked the other threads relating to these errors but most are related to FME Server which I'm not using. How do I go about installing the fmepy_autodesk_bim360docs module?
Thanks
  • Nov 1, 2023 11:33 AM UTC
Make sure to install or reinstall the BIM360 package:
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/options-FME-packages.htm
If possible, you may also want to consider replacing it with the Autodesk Docs package, as the BIM360 package has been deprecated: https://hub.safe.com/publishers/safe/packages/autodesk-docs
