Programmatically retrieve list of Web Connections on the FME Server
  • May 11, 2022 9:03 PM UTC
  • 128 views
jorma
Hi Folks - I am looking to use the API to get a list of all the Web Connections on the FME server. Has anyone done this before? Thanks
Best answer by birgit
I haven't done this myself but it looks like you need to use the following command: https://FMEServerName/fmerest/v3/security/categories/NamedConnections/resources?limit=-1&offset=-1
Please note the underlined text, you need to replace it with what is applicable to you. It's a GET request. Also don't forget that you need to send a token with your request or else it won't work.
birgit
Forum|alt.badge.img+25
  • May 12, 2022 7:12 AM UTC
jorma
  • May 12, 2022 7:35 AM UTC
Perfect! Works great... thanks @birgit​ !
