Problems reading XML
  • Oct 8, 2022 7:49 AM UTC
  • 17 views
michiedem
Forum|alt.badge.img+7
I have a large XML (4GB+) I have trouwble to read. I need all elements, however: pand_bagpandid (2) only becomes a feature when it's the only element selected.
If I check 1, I get alle elements execpt pand_bagpandid, when I select individual elements (3) I still get all elements except pand_bagpandid, if I only select pand_bagpandid I do get it, but I don't get any of the other elements.
I am inexperienced with xml and have ben struggeling with this for quite a bit now. The xml fragements show the same behavior. Flattening, fragmenting or exposing attributes didn't work for me eitherxml
danilo_fme
Forum|alt.badge.img+58
  • Oct 9, 2022 11:57 AM UTC
Hi @michiedem​  Could you share your data?
