Polygon Buffer Avoiding Overlaps
  • Jun 22, 2022 10:50 PM UTC
  • 5 replies
  • 287 views
kelvin.jenkins
Forum|alt.badge.img+5
I have polygons (closed polylines) that I want to buffer a fixed distance, removing any overlaps. Each Polygon has a unique ID and they need to remain individuals.
Below and attached are starting polygons
startAnd shown in red is what we want to achieve.
EndI've tried an array of Buffer/AreaOnAreaOverlays/Dissolvers, but I cant quite get what's needed and keep ending up with holes and artifacts.
Any ideas?
I've attached the road strings i'm buffering towards, incase that is useful
Best answer by geomancer
Thanks for the improved sample data. This seems to work on the data you provided.
Most of the work was in the corners where several polygons meet. The hole provided a nice extra challenge.
Mind that you may need to change the distance values in Bufferer, LineExtender and NeighborFinder.
Polygon_Buffer_Avoiding_Overlaps
geomancer
Forum|alt.badge.img+71
  • Jun 23, 2022 10:23 AM UTC
The polygons within a building block are not touching, you may want to remedy that first.
Not_touching
kelvin.jenkins
Not_touching
Ok, thanks,
I've attached another versions with touching boundaries.
What were you thinking the workflow might look like with overlapping boundaries?
geomancer
  • Jun 28, 2022 7:45 AM UTC
kelvin.jenkins
Thanks for your workflow, this is really great!
geomancer
  • Jul 13, 2022 10:23 AM UTC
You are welcome, it was a nice challenge
