original
  • Jan 24, 2023 9:36 AM UTC
  • 55 views
fmesafe.podpora
Forum|alt.badge.img+11
Can I have one more question? Is there a transformer within FME that could format CSV into plain text with formatting, see the attachment? Thank you very much
Forum|alt.badge.img+54
  • Jan 24, 2023 10:32 AM UTC
It's probably best to ask this as a separate question on the FME community. That way the results are there for others to see and others may be able to answer your question before i can
fmesafe.podpora
Hi. Ok, I will also ask a question in the community, but I prefer your answer because I know from experience that your answer is excellent. So if you have time, please answer. Do you think my problem is complicated? Thank you very much.
