order of FME Workbenches in a sequential manner
  • Nov 23, 2021 8:42 AM UTC
  • 5 replies
  • 443 views
Hi team,
As i am new to FME Desktop, I 've created 3 workbenches like Add, Update & delete processes. I need to run these workbenches in following order.
1.Add
2.Update
3.Delete
Kindly provide which transform can i use to fulfill the requirement without FME Server option.
It will be highly appreciate for your Solution.
Regards
VIPLAW
Best answer by theoconsortech
@viplove555​ you should create what we call a "master workspace". So here are the steps :
  • Open a new FME Workbench
  • Add a creator (to trigger) your process
  • Connect 3 workspaceRunner back to back
Here is an overview of what you should obtain :
image" data-fileid="0694Q00000FmyksQAB
You also need to setup the workspaceRunner parameters, so open those transformers, and specify which workspace (i.e. FMW) you need to run :
imagePS: you need to enter the path of your workspace where the box is red. Also, you might have to specify some parameters (publish parameters) if your workspace requires them.
Then run your workspace and you should be OK.
nielsgerrits
Forum|alt.badge.img+67
I think you are looking for the WorkspaceRunner. Using this you can use a parent workspace to run the child workspaces you created in de the order you need.
  • Nov 23, 2021 9:24 AM UTC
Hi Neilsgerrits,
Thanks for the swift responses, I've checked with "Worksapce runner" but aint able to get the proper output from it . Is there any sample "workspacerunner" is available in the forum??
Regards
VIPLAW
theoconsortech
Forum|alt.badge.img+19
  • Nov 23, 2021 6:55 PM UTC
  • Nov 24, 2021 4:38 AM UTC
Thanks for the well explained step -by-step solution @theodrogo​ ..Completely elated by your reply. 😊
theoconsortech
You welcome @viplove555​ !
