Onesided buffer - offsetcurvegenerator
  • Nov 11, 2021 9:05 AM UTC
  • 122 views
torbjornd
Forum|alt.badge.img+5
Hi.
I'm trying to create a onesided buffer, or actually a buffer with different radius on the right and left side of the line. I've read a post about using offsetcurvegenerator for accomplishing similar tasks. I've used the offsetcurvegenerator, but there are some areas where the transformer creates strange results.
 OffsetCurveGeneratorBlue lines are the original lines and the red lines are the result of the offsetcurvegenerator. Why is this?
One other question is that some of the results from the offsetcurvegenerator has multiple parts (IFMEMultiCurve), and the original features has just one part. What's the reason for this?
Torbjørn
caracadrian
Forum|alt.badge.img+23
  • Nov 11, 2021 4:23 PM UTC
Try GeometryRefiner before OffsetCurveGenerator. It should fix this error
muzhnasto
Forum|alt.badge.img+12
  • Nov 11, 2021 4:30 PM UTC
Hello. attach a sample of the data, perhaps it will help to get an answer to your question faster)
