Numbering segments of line
  • Oct 27, 2020 2:53 PM UTC
  • 207 views
torbjornd
Forum|alt.badge.img+5
Hi.
In one of my FME-workbenches I'm splitting lines at several points (water lines and devices) by using a PointOnLineOverlayer. After the splitting, I want to create a numbering of the new line segments according to the direction the line has been digitalized. I've tried using a counter with the ID of the lines as the countername, so I get a count based on the ID. But the result is not what I want. The numbering seems random.
As you can see from the first example (just a mockup), each line has an ID and you can see where the points are.Fme_nummerering1After I split my lines and calculate a new ID, I get this:
Fme_nummerering_wrongThe segment IDs are not numbered in the direction of the lines. What I want to achieve is this:
Fme_nummerering_correct
Do you have any suggetions?
Best answer by david_r
Just a thought, how about first setting M values on the entire polyline (MeasureGenerator), then sorting the clipped lines by the starting M value (MeasureExtractor + Sorter) to get them in the right order before the Counter.
Forum|alt.badge.img+54
  • Oct 27, 2020 2:57 PM UTC
Add a measure to your lines before splitting, you can then extract the measure at the start point of each line segment, and sort by this value before numbering with the counter
  • Oct 27, 2020 2:59 PM UTC
