new data becomes available.
  • Sep 5, 2022 10:42 AM UTC
  • 42 views
asadamjad
Participant
Forum|alt.badge.img+12
what I want are ArcGIS Layers to maintain old data. if no data is found in the next run, it needs to delete what’s in there and leave it as null until new data becomes available.
evieatsafe
Forum|alt.badge.img+28
  • Sep 9, 2022 10:49 PM UTC
Hi @asadamjad​ thanks for your question! This sounds like you would use the ChangeDetector transformer to compare two datasets, check out this article explaining how to use it: https://community.safe.com/s/article/change-detection-2
As well, if you need update or delete your data after checking the data check out this article: https://community.safe.com/s/article/data-loading-updating-and-deleting
