NeighborFinder: several matches for one street
  • Oct 20, 2021 7:31 AM UTC
  • 79 views
Is it possible to connect a coordinate with a street using for example NeighborFinder and generate several hits for one street if there are several coordinates close to the street? For example, if there are 5 coffee shops close to Arbitrarystreet, I want it to say that there are 5 coffee shops nearby and not just that there is a coffee shop nearby.
Thanks!
caracadrian
Forum|alt.badge.img+23
  • Oct 20, 2021 8:27 AM UTC
Enable Generate List in NeighborFinder then use ListElementCounter to count the elements in the list.
  • Oct 20, 2021 9:06 AM UTC
Thank you for your answer.
I have hundreds of streets and hundreds of coffee shops though. And the NeighborFinder seems to only associate the closest coffee shop with a street, even though I want the number of coffee shops within for example 50 m of a street.
  • Oct 20, 2021 9:13 AM UTC
Update: I solved it temporarily by buffering the coordinates to an area and using the LineOnAreaOverlayer which showed me the number of overlaps.
caracadrian
  • Oct 20, 2021 9:17 AM UTC
You can specify how many neighbours to find and a max distance
