My scenario is that I have to ensure that all polygons going through a process have fewer than 2000 vertices. These polys can vary in size and complexity quite significantly. Districts, towns, counties...
  • Oct 5, 2020 10:01 AM UTC
  • 38 views
I'm trying to build an expression in Generalizer's'tolerance' setting that address this in every scenario (I have a Tester for node count beforehand, so this will only have to deal with polys with 2000+ nodes). I assume it's related to the perimeter but I'm not getting very far.
Any suggestions gratefully received
Thanks
Paul
@paulc1​  Chopper has the option to break polygons by vertex count. There is also a GridChopper on FME HUB that is useful for areas with a large extent
itsmatt
Forum|alt.badge.img+48
  • Oct 5, 2020 8:33 PM UTC
You could use the looping function in a customer transformer to slowly increase the generalisation? This might avoid trying to build a 'smart' expression​.
  • Oct 6, 2020 8:58 AM UTC
ooh....good call.....
