Multiple SOAP requesta
  • Apr 19, 2023 2:53 PM UTC
  • 87 views
Hi all!
I want to request the monthly average exchange rate for a whole year.
So far, I have transformed the soap request to xml and pasted it into the xml templater.
XML request in the XML templater requesting the monthly average rate in January I then post the request by the HTTPCaller and extract attributes by means of the XMLFragmenter. This works fine as long as I request the monthly average exchange rate of one month of a specified year at the time.
However, here is were I am stuck: To get all monthly average exchange rate I would need to post 12 request, one for each month.
My idea was to do this by means of sub templates, but I have not succeeded in doing so. I tried to import a file containing a list from 1 to 12 (1= january...12=december) and connect this list to the sub port.
The root xml requestTrying out the sub template I could add 12 xml templater and httpcaller instead, but this does not seem very effective.
Is it possible to achieve this by sub template?
Or is there a way to dublicate requests or is it in some way possible to loop through the request?
Any ideas and help are welcome!
Thanks in advance!
Best answer by daveatsafe
Hi @ingridantonsen​,
Please use a Cloner transformer to create 12 copies of the year feature, one for each month. The cloned copies will have a copy number on them that can be used to set the month in the XMLTemplater:
Screen Shot 2023-04-19 at 11.25.04 AMThe Cloner begins counting at 0, so you will need to use an AttributeCreator to add 1 to the count attribute to get correct month values.
Use the following in the template:
<soap:Envelope xmlns:soap="http://www.w3.org/2003/05/soap-envelope" xmlns:xsd="http://swea.riksbank.se/xsd">
    <soap:Header/>
    <soap:Body>
        <xsd:getMonthlyAverageExchangeRates>
            <year>$(Year)</year>
            <month>{fme:get-attribute("_month")}</month>
            <languageid>en</languageid>
        </xsd:getMonthlyAverageExchangeRates>
    </soap:Body>
</soap:Envelope>
You will now have 12 request features for the HTTPCaller - one for each month.
daveatsafe
Forum|alt.badge.img+24
  • Apr 19, 2023 6:32 PM UTC
    <soap:Header/>
    <soap:Body>
    </soap:Body>
</soap:Envelope>
Thanks you so very much for your help and effort @daveatsafe​ . It works perfectly. Thanks again!
