MS Excel almost doubling in size when written by FME
  • May 25, 2023 6:04 PM UTC
  • 78 views
mferwerda3
Have and excel spreadsheet, roughly 90 mb, if II make a workspace that simply reads that excel file and writes it, the size of the written excel file by FME is about 179 mb.
I am just using the defaults on both the reader and writer. If I open the file in excel and clear all cell formatting, and save, it drops the file size down to about 109 mb. Any Ideas why FME is writing a file that is almost double the size of the source file? and is there any way to clear out any formatting, assuming that is where the bloat is coming from ?
evieatsafe
Forum|alt.badge.img+28
  • May 27, 2023 12:32 AM UTC
Hi @mferwerda3​ could you share some screenshots of where you are seeing this (e.g. file manager), and maybe a sample file and log? There might be more things we could do with additional information, thanks!
mferwerda3
  • May 30, 2023 3:58 PM UTC
Using windows explorer, the original file is 90 mb and the same file read and written by FME is 160 mb
Attached is a dummy data set I made up, but similar data types, original size is 17 mb, when written by FME i tis 23 MB
