Missing Files when i Aggregate the fileds
  • Sep 24, 2022 12:19 AM UTC
  • 7 replies
  • 76 views
asadamjad
Participant
Forum|alt.badge.img+12
In the source file, i have 4 files but when I aggregate the fields it gives me only two files
please anyhow help me where I doing wrong
Source file
imageAfter Aggregate the fields
Best answer by carmijo
I think i see the problem and can share how to fix it.
  1. Change this field to do nothing (don't remove it) in attributemanager_13image
  2. Include field kml_document_href in the group by parameter in the aggregator_10 transformerimage
  3. Now you'll have all data and not just 7 and 8, as seen hereimage
If i've provided something helpful, please upvote the comment. If i've provided a solution, please mark it as 'Best Answer'. This helps the community find solutions when your question is referenced.
If I didn't provide a solution, please let me know if I can help further. Thanks! 🙂
carmijo
  • Sep 24, 2022 12:31 AM UTC
Hi @asadamjad​, are you sure you attached the correct workspace? I see two aggregators but neither are outputting only 2 featuresimage
asadamjad
Participant
  • Participant
  • Sep 24, 2022 12:34 AM UTC
yes, its correct Workspace .. that's the problem if you see from start its giving you 5 Files
carmijo
  • Sep 24, 2022 12:50 AM UTC
I see. i think the problem starts with attributemanager_13 where you remove these fields
asadamjad
Participant
  • Participant
  • Sep 24, 2022 12:52 AM UTC
can you help me out on this please
asadamjad
Participant
  • Participant
  • Sep 24, 2022 12:54 AM UTC
Asnd time must be shown ... all time TD
carmijo
  • Sep 24, 2022 12:57 AM UTC
i can try! can you show me how you want the data to look at the end?
carmijo
  • Sep 24, 2022 1:07 AM UTC
