merge 2 building parts without connecting line?
  • Apr 22, 2022 8:36 AM UTC
  • 94 views
3d_clemens_lpz
Hello,
we have several 3D buildings that need to be extended downwards. That's why we applied the extruder in conjunction with the terrain model. After that we aggregated the two parts (aggregator).
However, then when we turn on the contours, there is the undesirable effect that there is a line between the 3D building and the extruder building part. (see example, highlighted in yellow)
How can we remove this line?
Or is there another way to extend the buildings downwards?
Best answer by dustin
thanks for your answer @dustin​
i cant find like this in the FME Hub, do you have a link? :)
@3d_clemens_lpz​
SolidDissolver | FME Hub (safe.com)
dustin
Forum|alt.badge.img+36
  • Apr 22, 2022 12:43 PM UTC
The Aggregator does not dissolve the features that enter, it only aggregates them. You will need to look into the SolidDissolver. This is a transformer that comes down with the FME2022 install, but is available on the FME Hub in versions prior to that.
3d_clemens_lpz
dustin
  • Apr 22, 2022 1:01 PM UTC
@3d_clemens_lpz​
