Many workspaces referencing one external parameter?
  • Dec 29, 2020 3:15 AM UTC
  • 36 views
I have emailers embedded in many workspaces. Within each I have 1 parameter for the email password which applies to all emailers within each workspace but I am wondering if it's possible for multiple workspaces to reference the 1 email password parameter so I only have to change this in 1 place every 3 months as my password changes?
  • Dec 29, 2020 3:32 PM UTC
I would ​use user parameters. Whenever you can, also think about security of your passwords!
User parameters are like global variables across your entire worksheet that can be called from anywhere.​ Also very helpful when you want to do batch processing.
davtorgh
Forum|alt.badge.img+12
  • Dec 29, 2020 3:44 PM UTC
Hi @tfsrichard​ ,
web connections are the preferred method used by FME to store credential in a safe way. If you can send e-mails from a GMail account you can create a web connection (Tools -> FME Options -> Web Connections) and store the password there once.
If you need to use a generic SMTP server you could store the password in a text file and read it as an attribute when needed, although I think it's not a good practice store passwords in clear text file.
Hope that helps!
