List of which jobs have webhooks and when tokens expire?
  • Sep 1, 2022 8:57 PM UTC
  • 43 views
alim2
Participant
Is there a way to list out which published workbenches have 1 or more webhooks set up, and if so, when the token for each webhook expires?
siennaatsafe
Forum|alt.badge.img+12
Hi @alim2​ ,
Unfortunately, I believe you'd have to do this in a bit of a roundabout way.
I believe you'd have to get all the tokens and find which ones are associated with Webhooks. I created an example workspace of how this could work with the FME Server API.
However, please note that Automations can also contain webhooks as well, so they could potentially trigger a workspace as well. However, these triggers don't contain expirable tokens.
