Licenses get stuck in the same computer
  • Sep 26, 2022 8:47 AM UTC
  • 100 views
Hello,
I have two floating licenses on the server, i habe been using in diferent computers but with two in specific it always get the license stuck on the server. I connecetd to both computers and there is no service or application of FME running but when i retrieve the status of the licenses in the server it always appears both of them.
I know i can fix by stopping and restarting the service, i would like to know if there is another solution so idont have to go each day to the server and free the licenses.
Best Regards.
andreaatsafe
Forum|alt.badge.img+17
@asier​
There are some things I'd review:
  • ensure there are no FME-related processes running under any user for the machines that are reporting to have the license. These could be FME Workbench, FME Data Inspector, fmeobjectsworker.exe, fme.exe
  • Review if the licenses have been borrowed on the machine
    • On the floating license server, what are the results of running lmutil lmstat -a -c <license file> (aka using the command from the documentation on monitoring the floating license)
    • On the client machines that are reporting having an FME license, review the resolution in this article and remove any possible borrow registry keys
Hope this information helps!
Andrea
  • Oct 3, 2022 9:12 AM UTC
Sorry for the late response i have been out for a while.
I would try what you suggest and i will keep you inform if it works or not.
Thank you.
