license related issues
  • Aug 24, 2023 9:50 AM UTC
  • 76 views
viviancfhung
We updated our FME server from 2022.0.1 to 2023.0.1, But
When I try to convert a FGDB file to another format. I get the error screen as below
imageWe installed Arcgis pro 2.9.3 already.
But it is working fine in FEM server 2022.0.1
  • Aug 24, 2023 9:59 AM UTC
Those look more like debug messages than error messages, is that possible? What happens if you turn off debug log messages, republish the workspace and re-run it?
viviancfhung
  • Aug 24, 2023 10:11 AM UTC
Sorry, the error is like below
  • Aug 24, 2023 11:34 AM UTC
Did you already look at the referenced article? https://community.safe.com/s/article/geodatabase-formats-missing-greyed-out-or-have-unm
There's notably a section about some important points regarding the installation of ArcGIS Pro.
That said, please note: FME Server requires that ArcGIS Enterprise or ArcGIS Server software be installed. While it is technically possible for FME Server to use ArcGIS Pro, we have been informed by Esri Inc. that the use of ArcGIS Desktop or ArcGIS Pro in a server context violates Esri's license terms.
https://community.safe.com/s/article/using-fme-server-with-esri-software
viviancfhung
  • Aug 25, 2023 5:16 AM UTC
Thanks, We will check
