JSON Help with extract attributes
  • Jun 12, 2022 7:59 PM UTC
  • 77 views
dor1411993
Hello!
I have a json text which I got from airtable HttpCaller.
I want to read the attributes as normal attributes, and I have some hard time with that.
I think I know what should I do:
imageFormat it, and then expose the attributes with JSONFragmenter
But It does not enter the attributes into my fileds:
imageWhat should I do?
I tried to do a lot of variations in the JSON Query, but noting helped..
I attached here the work sample..
Thanks you all!
Best answer by danilo_fme
Hi @dor1411993​
I edited your transformer JSONFragmenter - the Query:
json["records"][*]["fields"]
The results in FME Data Inspector:
Results
Thanks in Advance,
Danilo
danilo_fme
Forum|alt.badge.img+58
  • Jun 13, 2022 12:06 AM UTC
Hi @dor1411993​
Results
Thanks in Advance,
Danilo
dor1411993
  • Jun 13, 2022 4:50 AM UTC
Thanks very much!
@danilo_fme​
danilo_fme
  • Jun 13, 2022 10:38 AM UTC
Thanks very much!
@danilo_fme​
Thanks for update. I'm happy to help you!
