Issues with the LineCombiner - possible bug
  • Apr 26, 2023 3:41 PM UTC
  • 8 replies
  • 177 views
I'm finding that the LineCombiner is causing issues when combined with an AreaBuilder. The non-combined lines in a workspace I have created successfully create areas but, when the lines are combined, they then make up incomplete areas.
You can see in the below image that, once one of the line datasets go through the LineCombiner, they do not successfully create the areas.
LineCombiner bug
Is this a bug?
dustin
Forum|alt.badge.img+36
  • Apr 26, 2023 4:18 PM UTC
If you insert an Intersector between the LineCombiner and the AreaBuilder, do you get the expected results? The Intersected port would be fed into the AreaBuilder.
  • Apr 26, 2023 4:33 PM UTC
Yes, no intersections are encountered. 18 rows go in, 18 come out
dustin
  • Apr 26, 2023 4:49 PM UTC
Hmm, I'd be curious to see what happens if you feed both the 18 combined lines and the other 132 lines into the Intersector. 95% of the time when I have issues with the AreaBuilder, an Intersector prior will take care of it.
  • Apr 26, 2023 6:43 PM UTC
The Intersector does work so that is a useful addition, thanks for the help. I still think that the LineCombiner-AreaBuilder combination appears to be a bit buggy.
LineCombiner - IntersectorLineCombiner - No intersector
DanAtSafe
Forum|alt.badge.img+23
  • Apr 26, 2023 7:08 PM UTC
Hi @bi​ There's nothing buggy about it - the AreaBuilder requires input lines to be properly noded. In your case the Intersector created 159 lines from 150.
  • Apr 26, 2023 8:31 PM UTC
The data were properly noded before the linecombiner and the areabuilder worked. Something in the linecombiner transformer changed that​, suggesting the start and/or end nodes were edited in some way
DanAtSafe
  • Apr 26, 2023 9:23 PM UTC
@bi​ Please file a case at https://community.safe.com/s/submit-case if you think is bug. Thanks!
  • Apr 27, 2023 11:01 AM UTC
You could also pass all your line segments (before the LineCombiner) through a Snapper set to end point snapping. If you get anything out of the Snapped output port, it would indicate that the line segments aren't correctly noded.
