Is there a way to check if FME form is licensed from the command line?
  • Oct 29, 2023 9:14 PM UTC
  • 124 views
james_c_452
Forum|alt.badge.img+10
I haven't quite been able to work this out. Is there a way to check if FME form is licensed from the command line? Before you try to open FME.
I ask because I am making a batch file and I wish to check before it starts to let the user know if they need to update it
Any help would be appreciated
Regards
Best answer by david_r
Try the following command:
fme.exe info
The output will include information about:
Edition
Version
OS Locale Name
OS Encoding
Process Encoding
FME API version
Registration Key
Registration
Serial Number
Customer Number
Home Folder
Operating System
 You can then use e.g. Powershell to extract the license information from the "Registration" entry.
  • Oct 30, 2023 8:50 AM UTC
fme.exe info
Edition
Version
OS Locale Name
OS Encoding
Process Encoding
FME API version
Registration Key
Registration
Serial Number
Customer Number
Home Folder
Operating System
james_c_452
  • Oct 31, 2023 9:22 PM UTC
Thanks @david_r​ !
I ended up using a different method in a Windows batch because it was quicker for me not to work out how to use Powershell, but its the same result basically the same except that you need to know what the license is rather than being a wildcard.
find "*LICENSE_NAME*" "C:\\ProgramData\\Safe Software\\FME\\Licenses\\fme_license.dat"
if %ERRORLEVEL% EQU 0 (
echo FME is unlicensed
) else (
echo FME is licensed
