Is the GeometryFilter altering the data or the way the data is presented to the writer?
  • Jul 11, 2023 6:52 AM UTC
  • 93 views
ponceta
Forum|alt.badge.img+7
I have a dynamic workflow that writes spatial data from a MS SQL Server to a postgis database. Since my inital data is not always restrictive on geometry types, I want to ensure that Geometry types are well defined in my destination database.
I had an issue with mixed lines and multilines that I solved using an aggregator (destination geometry (multilinestring) ) but I had some geometry collections creating some issues when writing data so I added a GeometryFilter.
Visually no feature is filtered (only lines) and the writing is doing great. Removing this filter will make the writing fail.
My question is then : Is the GeometryFilter altering the data or the way the data is presented to the writer?
Best answer by david_r
If you're using Simple mode in the GeometryFilter, FME will try to homogenize heterogeneous collections, see the manual, under Parameters / General / Mode:
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/Transformers/geometryfilter.htm
  • Jul 11, 2023 9:06 AM UTC
ponceta
  • Jul 11, 2023 11:21 AM UTC
So there's actually some little magic behind the scenes! Thank you for your feedback!
