Is it posible to use one DateTimeStamper for more than one output
  • Aug 18, 2021 11:57 AM UTC
  • 116 views
scarrabee
Participant
I use this guide to add the date to my output file and foldernames:
https://community.safe.com/s/article/including-dates-into-the-names-of-output-files-or
Works like a charm but slows down my fme with large datasets. Now I don't need the DateTimestamp in my data, only in the filename. So I wonder if there is a way to re-use one DateTimestamp for more than one output.
  • All the outputs use the same Writer
  • All outputs have a different input
  • I don't need the datetimestamp in the data
Small test model how it is now (and works):DateTimeStamper_1How I would want it (but doesn't work like this):
DateTimeStamper_2The second version is 40% faster than the first...
Best answer by nielsgerrits
You can also open the writer parameters and add something like
@Left(@DateTimeNow(),14)
in the target folder / name.
This is probably even faster because the FeatureMerger is a blocking transformer.
Forum|alt.badge.img+63
Yes, in fact, you can set it up with only one DateTimeStamper that's only triggered once:
Set up a Creator and a DateTimeStamper. The Creator triggers once when the workspace starts and creates a no-geometry feature that then gets a DateTimeStamp. Run that through a FeatureMerger with your actual data so that the single feature with the DateTImeStamp goes in as a Supplier and your data as Requestor. In the parameters set the join keys to some static value on both sides (1 and 1 for example) so it will simply join everything.
This also circumvents the issue where some of your features end up with a different timestamp if the workspace runs too long 😃
nielsgerrits
Forum|alt.badge.img+67
  • Aug 18, 2021 12:30 PM UTC
scarrabee
Participant
  • Participant
  • Aug 30, 2021 7:42 AM UTC
Thx,
Both answers work but yours is very clean :)
