Inspector doesn't open up automatically anymore
  • Feb 17, 2018 5:03 PM UTC
  • 82 views
fmenco
It used to work fine. I had a workbench with inspectors, and after running the translation, the inspector would open up, displaying the data from al the inspectors.
That has stopped.
I tried doing what was recommended in here: https://knowledge.safe.com/questions/4186/data-inspector-will-not-open.html
But that doesn't work either. I can't even manually inspect a reader or writer. I have to write to intermediate writers to be able to inspect my data, and then open that dataset within the inspector. Running with inspection on , doesn't help either.
Help.
Forum|alt.badge.img+63
What version of FME and what operating system are you using?
If this problem persists after all the steps in that article and a reboot I would try reinstalling FME, just in case something has gone wrong in either the application or the registry.
