Inspect dataset to identify areas not covered by another dataset by field values
  • Nov 15, 2023 3:33 AM UTC
  • 112 views
pinkopo
Forum|alt.badge.img+5
Hi guys i just need to find a way to identify the areas on a dataset which is not covered by each of the field values from another dataset..
I also need this inspection to be done by one of the fields. e.g. my input layer A needs to get scanned through to find out areas not covered by Layer B. but on layer B there is a field and each field value will need to be scanned separately and identified at the output..
Im trying clipper - outside - group by attribute but doesnt seem can give me the output i need..
Thanks!
Best answer by ctredinnick
Hi ctredinnick. do you mean on both input dataset i need to have this attribute value? sorry i got bit confused...
Layer A is my area of interest to be tested,
Layer B is my "constraint" Layer with a field with different field values to indicate different constraints.
each field value (constraint) in layer B need to be tested to identify their non-overlap part with Layer A..
hopefully there is an easy solution for this...
Something like this I think it what you're looking for: imageMost of it is setting up the features, the key is having multiple copies of layer A going into the clipper
ctredinnick
Forum|alt.badge.img+22
  • Nov 15, 2023 5:20 AM UTC
To do a Group By on an overlap between different datasets, all features need to have the attribute.
So if you want to find what's outside with field value 1 on layer B, add field value 1 to all features on layer A, and you can do the Group By Clipper. To do the same with field value 2, have an entirely separate copy of layer A features, add field value 2 to it, run it through the same Clipper. Each time it needs to be a separate full set of features from layer A to be compared against.
If you have a large number of field values, you can make it dynamic by adding a list of all field values to A, then ListExploder to duplicate all the features once with every field value. Hope that makes sense.
pinkopo
  • Nov 15, 2023 7:19 AM UTC
ctredinnick
  • Nov 15, 2023 8:49 PM UTC
pinkopo
  • Nov 16, 2023 7:53 AM UTC
THANK YOU! this solved my issue perfectly
