Import to Esri Geodatabase ArcSDE
  • Mar 15, 2021 8:36 AM UTC
  • 98 views
Hi!
I'm stuck!
I want to import geoobjects to a Geodatabase SDE but I cant find where to choose feature dataset and class? I can se the note <not set> but where can I make that choice?
Thanks! /Erik
nielsgerrits
Forum|alt.badge.img+67
I don't use the classic writers so I can't help with that, but with a FeatureWriter it's easy peasy.
FeatureWriterSde
frro
Forum|alt.badge.img+17
  • Mar 15, 2021 8:59 AM UTC
Hi Erik,
When adding your writer you can also add your feature types (i.e. the Feature classes) by selecting them from the database. Just select the option "Import from Dataset..."
If you already have a writer in your workspace go to the Writers menu and select "Import Feature Types..."
//Fredrik
