IMDF Writer Not outputting "Building_ids" property.
  • Oct 6, 2020 5:08 PM UTC
  • 66 views
So I have this IMDF writer. Everything works fine except for this one property building_ids. The writer in safe says it is just a string. However, I have trouble making it generate output. In reality, it needs to look like this in the generated geojson: "building_ids" : ["8f0f9e75-860d-4050-a0f0-3483cd895a31"]
Best answer by brian.telintelo
I fixed this by just creating a list type for the variable, then safe populated the value correctly.
