i would like to have the same value of specific column for the same id but it depends on larger lengths for id_counter coulmn
  • Nov 18, 2021 9:50 AM UTC
  • 50 views
gogopotter90
Forum|alt.badge.img+14
I am not able to get the result that i want :
i would like to have the same value of difference column for the same id but it depends on larger lengths for id_counter column .
when we compare the row no.3 and row now.4 for id = 6
so the output should be for first row
id_counter = 1 /lengths = 2 /ID = 6/ difference = good
and the other row for the same id will be still the same
and the same idea with all rows .
if the value in difference column is the same for the same_id so the program should do nothing and keep it .
i was thinking to do it with matcher but i could not get the correct result .
questionthanks for help fme 2018
Best answer by redgeographics
If you use a Sorter to sort on the column ID first and then lengths (numeric, descending) you can then use a Sampler, grouped by ID, to take the 1st feature. Use that as a Supplier in a FeatureMerger and the not-sampled features as Requestors, making sure to set that to use the supplier values in case of attribute conflicts.
Screenshot 2021-11-18 at 11.04.42Something like this. Since you're on FME 2018 some parameters may be different, if you have the opportunity to upgrade that would be highly recommended.
Forum|alt.badge.img+63
