I would like to filter specific items from a list which contains multiple criteria. Would this be possible with ListElementFilter?
  • September 23, 2020
  • 196 views
rva1
I'm using Filtertype: Contains, and I would like to add muliple string values to Match Expression, like "string A" OR "string B" OR "string C". I've tried creating a User Parameter, but it didn't work... any idea's?
Best answer by ebygomm
It doesn't look like the ListElementFilter allows for multiple string filtering using Contains, you might be able to use the Regex match to do the same thing though
e.g. use Regular Expression Match and
string A|string B|string C
Forum|alt.badge.img+54
rva1
tnx for your reply...
that def did the trick;)
thank you!
