I’m using Interop via ArGIS and have developed 9 ETLs that need to run in order. I want to make things streamlined and run all 9 at once with one run command? I tried adding ETLs to a model but ran into problems.
  • Jun 14, 2022 4:53 PM UTC
  • 22 views
gmatt
Forum|alt.badge.img+63
One thing you can try is create one "controller" workspace, with a Creator and then 9 WorkspaceRunners, one after the other. You run the controller workspace with one command and then it will trigger the 9 separate ETL's.
