I have 20-30 Clients that I need to modify to point to a new license server. Can this be done without launching the Licensing Assistant on each client locally. In other words, is there a file I could edit or a registry value I could modify?
  • Jun 4, 2021 4:47 PM UTC
  • 123 views
andreaatsafe
Forum|alt.badge.img+17
Hi @twbell1963​ ,
You should be able to run a command-line prompt to update to the new license server name.
See the section “Licensing FME Desktop from the Windows Command Prompt” under “Post-Install Tasks” for details.
-Andrea
  • Jun 4, 2021 5:04 PM UTC
Hi @twbell1963​ ,
-Andrea
Thank you for the link. This method would still require me to log in locally. I am trying to accomplish this remotely.
andreaatsafe
You could open and edit the fme_license.dat file located in: C:\ProgramData\Safe Software\FME\Licenses
This file looks like this:
SERVER licensing Any
USE_SERVER
where "licensing" is the name of the license server.
If your organization updated license editions (eg. from Professional to Database), then the flexlm_config.dat file will need to be edited with the proper edition name as well.
Registered Product=database
FME Desktop Database Edition
Where for line 1 and 2: database would need to be updated to the new edition name.
  • Jun 4, 2021 6:38 PM UTC
Thank you so much. This is exactly what I have been searching for.
