I am trying to install the FME Desktop on my Ubuntu 20.04.1 laptop, but it doesn't work. Could you please help me to solve this problem? Thanks!
  • Jan 13, 2023 1:26 PM UTC
  • 12 replies
  • 287 views
debbiatsafe
Forum|alt.badge.img+24
Hello @momeniiman​
It looks like you are using dpkg to install FME based on the screenshot you shared. dkpg does not install missing dependencies and may be the cause of the errors you are seeing.
I would recommend confirming FME Desktop was not installed (ie. /opt/fme-desktop-2022/ does not exist). If the folder doesn't exist, try using gdebi to install FME as recommended in our installation documentation. You may need to install gdebi first with 'sudo apt install gdebi-core'.
  • Jan 13, 2023 8:47 PM UTC
Hello @momeniiman​
Thanks!
The folder you mentioned exists on my computer. Now, what should I do? Removing it?
  • Jan 13, 2023 9:16 PM UTC
Hello @momeniiman​
I uninstalled the FME completely (purge) and tried to reinstall it using gdebi. But again didn't work. Please take a look at the attached picture. I would really appreciate it if you could help me to solve this problem.
debbiatsafe
The error in your most recent screenshot indicates a dependency for FME (libboost-chrono) cannot be installed. That may be due to several reasons including outdated libraries, the libboost-chrono not available from the repository your system is downloading from, etc.
Please ensure the Linux system libraries are up-to-date using the following command:
sudo apt update && sudo apt upgrade
After doing this, try installing FME again (uninstall FME first if /opt/fme-desktop-2022/ already exists). If the error persists after doing this, you can to try manually installing libboost-chrono and then installing FME again.
  • Jan 13, 2023 11:05 PM UTC
Thanks for your response.
My Ubuntu is up-to-date "sudo apt update" and "sudo apt upgrade" and nothing changed. I don't know how to install this package manually ...
  • Jan 13, 2023 11:08 PM UTC
It seems that my system has a more up-to-date package and cannot downgrade it?
Am I right?
debbiatsafe
FME Desktop 2022 does not appear to have a dependency on libboost-atomic. It does depend on several other libboost-* libraries (ie. libboost-chrono, libboost-filesystem, libboost-iostreams, libboost-locale, libboost-regex, libboost-system, libboost-thread).
You mentioned the machine is running Ubuntu 20.04.1. instead of the expected Ubuntu 20.04.5 if your system is up-to-date. Which Ubuntu-based distribution is installed and are you able to confirm the Ubuntu release used?
  • Jan 14, 2023 1:25 AM UTC
Thanks. The attached picture shows my OS specs.
  • Jan 14, 2023 1:48 AM UTC
Even after upgrading my Ubuntu to 20.1, the same error ...
debbiatsafe
Thank you for the screenshot. Note that your machine is running Ubuntu 22.04.1 and not Ubuntu 20.04.1 as previously mentioned.
Unfortunately, FME does not currently support Ubuntu 22.04. You can see a list of supported Linux distributions here. We are currently working on implementing support for 22.04 in FME 2023.
  • Jan 14, 2023 2:01 AM UTC
oooops!
Sorry for my mistake.
Thanks!
DanAtSafe
Forum|alt.badge.img+23
  • Feb 14, 2023 10:48 PM UTC
Hi @momeniiman​ FME 2023 betas are now also available for Ubuntu 22.04 "Jammy Jellyfish" at https://www.safe.com/support/downloads/#beta
