http caller rejects the request
  • Jan 5, 2023 9:30 AM UTC
  • 87 views
f.kemminje
Forum|alt.badge.img+11
I must use the http caller transformer to obtain the token value from the rest end point.
However, I am unable to connect via FME. postman returns valid output. I get a notice that reads "invalid clientid or secret," but when I use the identical parameters, Postman returns the response body. Why is FME unable to make it happen?
I made numerous adjustments but in vain. kindly assist
Best answer by david_r
You have to be mindful about how you're sending the request body with the parameters, the terminology and GUI between FME and Postman isn't quite identical. When encountering such problems, using something like Telerik Fiddler can be very helpful for debugging.
This should give similar results to Postman, notice how the upload body is specified:
pimc
Forum|alt.badge.img+8
  • Jan 5, 2023 9:48 AM UTC
Hi @f.kemminje​
Would you be able to share your HTTPCallers configuration?
Thanks!
  • Jan 5, 2023 10:09 AM UTC
