HTTP caller error message
  • Mar 30, 2018 12:57 PM UTC
  • 143 views
gis2020
Forum|alt.badge.img+5
Hi All,
i am using HTTP caller and getting wherein i am passing name text and checking certain parameters but getting an error message as "{"status":"ERROR","messageName":"com.tomtom.cpu.coredb.common.dto.ErrorMessage","messagePayload":{"errorCode":"APPLICATION_ERROR","errorInstanceId":"0da931e0-13b8-444f-aa78-534016b68679","errorDetailedMessage":"Illegal unquoted character ((CTRL-CHAR, code 13)): has to be escaped using backslash to be included in string value at [Source: org.apache.catalina.connector.CoyoteInputStream@708a538f; line: 1, column: 111]"}}"
Thought this is related to the extra space so i had tried to clean name sting but still it's giving me same error.
Can somebody help me with this ?
  • Mar 30, 2018 10:41 PM UTC
Hi @dandekarpriya, the error message seems to indicate that there is a newline (CR: Carriage Return, ASCII code = 13) at the position. If so, try replacing the newline with '\\n', or removing that if unnecessary.
"Illegal unquoted character ((CTRL-CHAR, code 13)): has to be escaped using backslash to be included in string value at ..."
gis2020
  • Apr 1, 2018 3:32 PM UTC
Thank you takshi . I also suspected the same thing so tried to replace it but then again it gave me the same result.so i am not sure what should i do now to resolve this.
  • Apr 1, 2018 4:07 PM UTC
Has any change in the error message appeared after you replaced a newline? Exactly same as before?
  • Apr 3, 2018 7:35 AM UTC
The error message seems to come from the server, so if possible, have a look in the server logs to see what's going on.
Have you tried using the TextEncoder with URL (percent encoding) on your parameters before transmitting to the server?
