How to use construct a URL to start an FME workspace
  • Dec 15, 2022 4:20 AM UTC
  • 142 views
pauledrummond
Hi.
I am wanting to utilize a webhook to kick off a process and have set up a sample site based on Send Source Data to FME Server with HTTP POST (safe.com).
This example uses a text file to kick off the process but I am wanting to use the webhook URL with a parameter (key field).
Is this possible?
If so, what would I use as the initiator of the workspace and how would I pull in the parameter?
Any help would be most welcome!
Best answer by itsmatt
Take a look here at the transformation services
https://docs.safe.com/fme/html/FME_Server_Documentation/ReferenceManual/transformation_svcs.html
There are several ways to trigger a workspace depending on how you want to handle the results. The doc outlines how construct the rest call.
In addition you can use the 'create a webhook' method directly in FME Server from the Run a Workspace page, this method is nice because it also creates a token at the same time:
itsmatt
Forum|alt.badge.img+48
  • Dec 15, 2022 8:37 AM UTC
pauledrummond
  • Dec 16, 2022 12:41 AM UTC
Thank you for your answer. I really appreciate it.
You have saved me so much time!
Regards, Paul
