How to turn on "inline inspector"?
  • Jan 30, 2023 9:56 AM UTC
  • 71 views
aron
Forum|alt.badge.img+16
I was watching the  OpenAI GPT-3 seminar the other day and the presenters had some magic turned on that allowed them to inspect transformers without attaching the usual inspectors. See image for a better explanation of what I am after. How do I turn on this feature/s?
inspector
Best answer by ebygomm
If the magnifying glass is greyed out, it's because you haven't got any cached data to inspect yet. The workspace will need to be run to at least that transformer before you can inspect the data
Forum|alt.badge.img+54
  • Jan 30, 2023 10:12 AM UTC
aron
  • Feb 1, 2023 10:48 AM UTC
Thanks! That does the trick. A follow up question: The setting resets every time I run the workspace, is supposed to do that?
saraatsafe
Forum|alt.badge.img+13
  • Feb 1, 2023 7:19 PM UTC
Hi @aron, Feature Caching should stay on once you have enabled it (even after you close and re-open workbench again). You can maybe try deleting your temporary files to see if that provides a quick fix: In the toolbar, Tools > Purge Temporary Files. I hope that helps!
