How to transpose my dataset to the desired format?
  • Aug 16, 2021 9:44 AM UTC
  • 86 views
Hello,
I am struggling with transforming a dataset that I have to the desired format.
I have a table that looks (for example) like this:
ID;16;50;60;75
X1;10;25;80;95
X2;30;30;90;
X3;25;;80;100
The first issue is that I need to use the column headers to get classes:
0-16, 16-50, 50-60, 60-75
But for ID X3 the value in column 50 is missing and therefore I need to get the class 16-60 (instead of 16-50 as is the case for ID X1 and X2).
I don't know how to create this in FME.
Secondly, I need to calculate the value for each class by substracting the values from each other. So for ID X1 I need the following result:
Class 0-16 = 10
Class 16-50 = 15
Class 50-60 = 55
Class 60-75 = 15
Class >75 = 5
Besides, I want the classes as an upper- and lower limit column.
So the final result that I need for the three ID's is:
ID;UPPER_LIMIT;LOWER_LIMIT;VALUE
X1;16;0;10
X1;50;16;15
X1;60;50;55
X1;75;60;15
X1;;75;5
X2;16;0;30
X2;50;16;0
X2;60;50;60
X2;;60;10
X3;16;0;25
X3;60;16;55
X3;75;60;20
X3;;75;0
I hope my explanation makes sense. The attachment might make it a bit more visual.
Thanks in advance!
Eva
Best answer by nielsgerrits
One way to do this is to use the AttributeExploder to explode the columns into features. Then you can start rename and calculate.
The other part you need is "Enable Adjacent Feature Attributes" in the AttributeCreator so you can use values of previous rows. Working workspace template attached.
nielsgerrits
Forum|alt.badge.img+67
nielsgerrits
  • Aug 17, 2021 5:39 AM UTC
  • Aug 17, 2021 12:28 PM UTC
Thank you so much @nielsgerrits​! It is a very understandable workbench :-) It works perfectly!
nielsgerrits
Cheers, it was a nice puzzle. Thanks for the complete and clear question :)
