How to setup a folder that can be written to from FME Server
  • Dec 5, 2022 11:02 PM UTC
  • 184 views
tcronin
Forum|alt.badge.img+4
I created a Service account called svc_fme, and it has write access to a folder. The service account is what is setup for running the FME Server components except DB. Thinking same logic as Esri Service access for FME Service. I have an ETL on FME Server that is not writing to the desired location. How do I set this up?
stefanh
Forum|alt.badge.img+8
  • Dec 6, 2022 9:06 AM UTC
How are you writing to the the desired location? Are you using the mapped network drive or the UNC-path?
In my case only the UNC-path is working.
This might also be the solution in your case.
tcronin
  • Dec 7, 2022 6:31 AM UTC
I probably have mapped drives as it seems to default to that. I set UNC but they seem to switch, so I can check that out. Thank you for the heads up.
tcronin
  • Dec 7, 2022 6:45 AM UTC
Thank you again, I believe its running as I expect. UNC seems to do the trick.
