How to set up a config for readers and writers that refer to files in a folder.
  • Jan 25, 2021 3:28 AM UTC
  • 174 views
I have several fmw files that read and/or write to a particular folder structure. But sometimes the location of the folder structure changes servers. So i'm wanting a way to set a root variable for readers/writers so i only have to update the one variable instead of updating all fmw readers/writers.
--------------------UPDATE--------------------
I need to add, my intention is to have one variable/setting/config that is globally available across all my workspaces. So changing one configuration would affect all workspaces.
For example, in a shapefile writer, the dataset location is d:\\folder\\to\\file.shp, but I'd like to change the location to something like $(GlobalVar)\\folder\\to\\file.shp. Where GlobalVar is available across all workspaces.
caracadrian
Forum|alt.badge.img+23
  • Jan 25, 2021 5:58 AM UTC
You can setup a User Parameter of type Folder and use that in your Readers and Writers.
Folder Parameter
  • Jan 25, 2021 7:16 AM UTC
Folder Parameter
Setting this works well in the same workspace. I swapped to another workspace and couldn't find it, though. How can I get this parameter to be globally exposed across all workspaces?
  • Jan 25, 2021 9:13 AM UTC
Have a look at the suggestion from @nielsg​  here: https://community.safe.com/s/question/0D54Q000080hIbySAE/how-can-i-script-a-connection-parameter-with-python
caracadrian
  • Jan 25, 2021 12:20 PM UTC
Another way to do it is to store your path in a file (lets say .csv), read the file and join your data with the path attribute from that file. I am not a fan of scripts 😐
It's not the most elegant solution, it requires creating a join attribute on your data, longer processing time and to modify all your existing workspaces.
